rdouma
May 19, 2022Guide
I can't access my admin panel nor app
I can't access my admin panel nor app, but on the bright side the MAXINT overflow issue for SNMP has been solved it appears; that seems to finally work past having received/sent MAXINT bytes.
rdouma
May 19, 2022Guide
Also, I tried a different browser but the message is quite clear; 192.168.1.1 simply seems to have nothing listening on port 80.
May 19, 2022Guru - Experienced User
You can wait for a fix to come thru or a reset will need to be done for more immediate access.
Contact NG support about the fix.
