jk2017
May 26, 2022Aspirant
I do not login to my router too often...
I do not login to my router too often, but today I needed to check something and hit this issue.
Is it correct that if I wait 'some time' it will get updated and (hopefully) fixed?.
I don't reall...
- Jun 15, 2022
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
May 26, 2022Guru - Experienced User
Either wait, contact NG support or factory reset if you need more immediate access.
- jk2017Jun 15, 2022Aspirant
Now 3 weeks later I'm still not able to log in to my RBR750.
My WiFi is working, except for the non-access to the setting, so I'm a little weary of factory resetting the router.
But I guess that is my only option now. Download Firmware-Version-v4-6-8-2, factory reset router and satellites, then upgrade.
