esp4p3
Jun 01, 2022Initiate
I got the patch directly from Netgear
I got the patch directly from Netgear to fix the issue with V4.6.8.2_2.1.9 not being able to access the router admin via web or mobile app. The patch fixed the issue but now I'm having connection iss...
esp4p3
Jun 02, 2022Initiate
Thanks for the reply. I was able to get the router stable by applying configuration as outlined here:
I'm not sure what exactly was causing the issue but it seems to be resolved.
Jun 02, 2022Guru - Experienced User
Can you tell us exactly what changes you applied from that list?
