oakviewdad
Oct 28, 2022Aspirant
I had orbi 850s that worked fine but my 960s intermittently disconnect
Hello, I suspect I'm experiencing the same problem. I had orbi 850s that worked fine but my 960s intermittently disconnect, especially if I have the network arranged in serial (router - sat 1 - sat ...
- Nov 04, 2022
Good news! The firmware resolved my problems; it now works as it should in my house, even in my preferred daisy chain (R -> Sat1 -> Sat2) config! great coverage and performance and now without the reliability issue.
Oct 30, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
oakviewdad wrote:
Hello, I suspect I'm experiencing the same problem. I had orbi 850s that worked fine but my 960s intermittently disconnect, especially if I have the network arranged in serial (router - sat 1 - sat 2) which is the ideal config for my home because to arrange in star formation would mean that I need to run hard-wire from cable modem across half the house to support the router rather than use it as a wired back-haul for the first satellite. I have worked with support including tier three for a month and even after manual firmware upgrades the problem persists. If anyone got to the bottom of this, I'd appreciate any insight. I will update if we find a fix if I'm able to keep toughing it out until resolved; I'm ready to throw in the towel and go to a different solution.
