bevrat
Jul 21, 2022Aspirant
I have 1000 mbps coming in through the internet provider
I am faced with a similar situation. I have 1000 mbps coming in through the internet provider. If I test directly to the internet via the cable, I get the expected bandwidth. If I plug the same ca...
Jul 21, 2022Guru - Experienced User
What speeds are you getting on WIRED and wireless?
You may not see anything near 900Mpbs on wifi. Most wifi speed top out at any where from 300-600Mpbs depending upon wifi device support and design. Wired speed should see near or over 900Mpbs.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
How many RBS do you have deployed?
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
