JohnYK
May 16, 2022Tutor
I have 1x RBR750 with 2x RBS750
I have exactly the same problem since last Friday. I have 1x RBR750 with 2x RBS750
The current firmware for RBR750 is V4.6.5.14
The current firmware for the RBS750 showing good in app is V4.6...
- May 17, 2022
Problem is solved after I manually down grade firmware to V4.6.5.14 for both satellites. Thank you!
Netgear, please don't push the new firmware to me. The ORBI system has been working great for me on firmware V4.6.5.14 and I don't want to waste another nice weekend on this kind of problem. Thank you!
May 16, 2022Guru - Experienced User
If you have access to the RBS web pages, I would download the v.14 FW files for the RES 750s on to a wired PC and downgrade the RBS to v.14 using the RBS web pages to send the FW files so that there on same version of FW as the RBR.
- JohnYKMay 17, 2022Tutor
Thank you very much for your suggestion! I will give it a try tonight.
I can only access one satellite using 10.0.0.2 that shows "Good" in the app and web. The other satellite shows "disconnected" without an IP address. Please may I ask how can I access that satellite? Thank you!
- FURRYe38May 17, 2022Guru - Experienced User
Try connecting the one RBS to the back of the RBR using a ethernet cable...
