hmogenson
Jun 13, 2022Tutor
I have a RBR750 router and two RBS750 satellites
I am having all the same issues described in this post. I have a RBR750 router and two RBS750 satellites. Everything was working fine for a long time, but I was away and when I returned, the satell...
Jun 13, 2022Guru - Experienced User
Was the system previously using v.4.6.8.2 FW before?
Can you ethernet connect one of the RBS to the back of the RBR and see if it appears in the RBRs web page?
- hmogensonJun 13, 2022Tutor
Unfortunately, I do not know the prior firmware of the router.
Similar to this prior thread, I tried connecting the router and satellite via network wire, but for me, I could not see the satellites on orbilogin.com or app.
Also, it seems that, while I can connect with a network wire to the satellite and get internet, the satellites are not functioning as true satellites and broadcasting wifi. I put the satellites back into their locations but the the wifi devices nearby (smart speaker, etc) are still not connecting to the satellites via wifi.
- FURRYe38Jun 14, 2022Guru - Experienced User
Only suggestion would be to update the RBR to v.2 and see if the RBR will resync fully or appear in the RBRs web page enough to access there web pages.
Might need to contact a forum moderator for additional help on this one.
- hmogensonJun 15, 2022Tutor
Thanks for your reply.
I don't know what you mean by v2. But, perhaps you are suggesting that I try to revert back to the previous version for the RBR750; V4.6.3.16.
By replying to this thread, I was really hoping to find out if the original poster found a solutions, since the situation seemed the same. Maybe I should start a new post to see if anyone has the answer.
