Remi_T
Jun 06, 2022Follower
I have frequent disconnects as well
Hi,
I have frequent disconnects as well.
My wife is getting mad.
Only on iPhone iOS devices.
Switching On and OFF The MAC address feature in netgear iOS network interface makes restore the connection.
ON or OFF the connection would drop again.
I see your suggestion to disable one satellite because of too powerfull signal too close.
I would like to keep both satellites so is there a way to decrease the power of the signal in the settings so I don’t have to disable a satellite ?
1 Reply
What Orbi model do you have?
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?What is the size of your home? Sq Ft?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
