Gyamada
Jun 08, 2023Follower
I have Orbi Satellie RBS750
I currently use wireless for two computers with my Orbi Netgear RBS 750 I use a proprietary Software program that is having problems they suggest that I use hard wire to connect to the Router but my Router only has two ports and suggestions?
Thank you
1 Reply
Install one of these behind the RBR or RBS:
https://www.netgear.com/business/wired/switches/unmanaged/gs105/
or
https://www.netgear.com/business/wired/switches/unmanaged/gs108/
Be sure to use CAT6 cabling.
