Mhackdo
Mar 13, 2023Aspirant
I have RBR750, May i know how to get to flash mode TFTP
Hi,
I have RBR750, May i know how to get to flash mode TFTP seems that when I released the reset button it is rebooting. and cant get the IP address. 192.168.1.1 is not working on TFTP mode.
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
Need to press the reset button for 30 seconds then release, then it send to PUT the command and upload the FW.
Make sure you enable tftp: https://www.thewindowsclub.com/enable-tftp-windows-10
Video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done:
https://www.youtube.com/watch?v=hXhMgQS5k1o
https://www.youtube.com/watch?v=R9DLrLQrpaw
Mac TFTP: https://www.petenetlive.com/KB/Article/0001247
Try nmrpflash:
https://github.com/jclehner/nmrpflash- StraqNETGEAR Expert
Do you have the WAN port connected? If so remove the WAN port, then factory reset again by pressing button for 30 seconds and try again
