BerserkRico
Dec 25, 2023Aspirant
I have updated my Orbi to 7.2.6.21
I have updated my Orbi to 7.2.6.21, but I live within Europe, and now I'm having connection issues.. Now what? (The "It's not for europe" notification wasn't there when I downloaded it)
BerserkRico
Ah, can I backup my settings and restore them in the downgraded version? But, will do that tomorrow then.
Dec 25, 2023Guru - Experienced User
You can however try the downgrade first then after the units are downgraded, power them OFF for 1 minute then back ON with the RBR first then RBS then test and check the system to see if problem is there or not with out loading any backup config.
