Gregg_Va
Jun 26, 2021Follower
I just installed an RB750 with two RBS750 satellites
I just installed an ORBI RB750 with two RBS750 satellites. A third satellite named Xerox is showing up on the network map. It isn't enabled and has no connected devices. It says it is an RBS750 and e...
Jun 27, 2021Guru - Experienced User
What Firmware version is currently loaded on the RBR and RBS? Should all be the same.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
What browser are you using? Happens with a different browser?
