V3_
Jun 25, 2022Follower
I just noticed some of my IoT devices were also being disconnected randomly because of my Satellite
Hello,
I just noticed some of my IoT devices were also being disconnected randomly because of my Satellite disabling its 2.4 GHz channel.
I followed your instructions and disabled the 20/40 M...
Jun 25, 2022Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Is the RBS connected directly being the RBR or is there a LAN switch in between?
What CAT# lan cable are you using? CAT6 is recommended.
