Dan007
Dec 24, 2023Aspirant
I just switched from Comcast to AT&T fiber, 2 Gb using a Humax BGW-320-500
thanks for this thread.
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/RBRE960B-compatibility-with-BGW320-500/m-p/2217810
I just switched from Comcast to AT&T fiber, 2 Gb us...
Dan007
Dec 30, 2023Aspirant
For reference this is a not uncommon speed test result off the Orbi. Even though the modem is getting 2300 up. The connection issues is beyond confusing to me.
Jan 01, 2024Guru - Experienced User
Can you try the Orbi system in AP Mode while the ISP ONT is in router mode and also disable the ONT wifi radios as well?
