Lewes1973
May 23, 2023Tutor
I need an advise to better split the devices between the router and the satellite I have.
My setup: Router in the house, satellite in the garage. Distance is around 15 meters with multiple walls. T...
- May 23, 2023
Its their own roaming protocol that makes them choose which to connect to.
did you try powering the devices off and back on? Maybe'll they'll connect to the stronger signal on a reboot.
Other option is a cheap extender that you hardwire to t he satellite and set with its own ssid to force them to connect to.
Ruins the point of a mesh but you can't fix someone else's poor coding.
May 24, 2023Guru - Experienced User
How many RBS are deployed?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️
What CAT# cable are you using to connect the RBS to the RBR?
Is the RBS directly connected to the RBR or is there a LAN switch in between them?
Lewes1973
May 25, 2023Tutor
How many RBS are deployed? 2
What is the size of your home? Sq Ft? 100 Square meter
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS ️ to begin with depending upon building materials when wirelessly connected. -> around 15 meters
What CAT# cable are you using to connect the RBS to the RBR? CAT 5e/6
Is the RBS directly connected to the RBR or is there a LAN switch in between them? Directly.
- FURRYe38May 25, 2023Guru - Experienced User
For that kind of size, two RBS maybe too much. Try turning OFF one RBS.
