Mikely
Jul 19, 2024Aspirant
I need to disable the 5 GHz band
I can't connect a 2.4 GHz device and need to login to my router, but I can't login. No option to reset password.
Jul 19, 2024Guru - Experienced User
What router do you have?
Are you logging into it using the app?
Using the browser?
What error are you getting? or where are you finding issues?
- MikelyJul 19, 2024Aspirant
RBK853, Bresser weather station.
I used a browser, but http://192.168.1.1 opens something from Zyxel, useless.
Everything I have is 5 GHz, but I need to temporarily disable the 5 GHz band to connect a 2.4 GHz only device.
- FURRYe38Jul 19, 2024Guru - Experienced User
What FW is loaded on the system?
v7 FW has the ability to setup a IoT network that you can use to get 2.4Ghz only devices connected.
https://kb.netgear.com/000064267/How-do-I-enable-or-disable-the-Internet-of-things-IoT-network-on-my-Orbi-WiFi-6E-System
https://kb.netgear.com/000064269/How-do-I-change-the-Internet-of-things-IoT-network-name-SSID-and-password-on-my-Orbi-WiFi-6E-SystemThe main WLAN can't disable the 5Ghz radio.
- plemansJul 19, 2024Guru - Experienced User
If you're getting a zyzel address, then you're probably in a double nat.
You'll want to fix that as some IoT devices have issues with double nats.
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There are 3 options, but only use 1.
1. Put the modem/gateway in modem only/pass-through mode. This disables its routing functions.
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway wirelessly enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. The Wi-Fi/ethernet still works, but it disables some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
