Mikely
Jul 19, 2024Aspirant
I need to disable the 5 GHz band
I can't connect a 2.4 GHz device and need to login to my router, but I can't login. No option to reset password.
Jul 19, 2024Guru - Experienced User
What router do you have?
Are you logging into it using the app?
Using the browser?
What error are you getting? or where are you finding issues?
Mikely
RBK853, Bresser weather station.
I used a browser, but http://192.168.1.1 opens something from Zyxel, useless.
Everything I have is 5 GHz, but I need to temporarily disable the 5 GHz band to connect a 2.4 GHz only device.
- FURRYe38Jul 19, 2024Guru - Experienced User
What FW is loaded on the system?
v7 FW has the ability to setup a IoT network that you can use to get 2.4Ghz only devices connected.
https://kb.netgear.com/000064267/How-do-I-enable-or-disable-the-Internet-of-things-IoT-network-on-my-Orbi-WiFi-6E-System
https://kb.netgear.com/000064269/How-do-I-change-the-Internet-of-things-IoT-network-name-SSID-and-password-on-my-Orbi-WiFi-6E-SystemThe main WLAN can't disable the 5Ghz radio.
- plemansJul 19, 2024Guru - Experienced User
If you're getting a zyzel address, then you're probably in a double nat.
You'll want to fix that as some IoT devices have issues with double nats.
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There are 3 options, but only use 1.
1. Put the modem/gateway in modem only/pass-through mode. This disables its routing functions.
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway wirelessly enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. The Wi-Fi/ethernet still works, but it disables some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
