norbertsf
Aug 22, 2022Aspirant
I need to keep restarting RBRE9606E (AXE) router to get fast wifi
I have a RBRE9606E (AXE), with 2 satellites. Firmware V6.0.3.85_3.1.15 I have noticed that last 3 to 4 days that I need to restart/unplug the Orbi router to get full speed wifi. By this I mean, I ...
- Sep 02, 2022
Just wanted to post what solved the issue I was having.
I also wanted to reply on how some of the suggestions ignored and overlook the problem that was described in my original post.
-There was no issue with the satellites.
-There was no issue with the comcast/xfinity modem in bridge mode.
-There is no problem with the size of the house.
Issue was with the Orbi Router, and I was standing right in front of it when testing and using the wifi from the router (not the satellites). The WIFI from router to wireless devices kept slowing down randomly to a crawl.
Anyhow.....
I reset the router back to factory settings and that solved the issue.
-Norberto
ekhalil
Aug 23, 2022Master
Question: Will restarting your phone or the device where you run the speed test on (rather than restarting Orbi) also give you the same improvement?
