dbnorton
May 08, 2022Tutor
I really hope they are able to fix this soon...
I really hope they are able to fix this soon. I really don't want to have to completely factory reset my router!! I have a lot of home automation stuff that would all have to be touched. Most of t...
May 08, 2022Guru - Experienced User
Be sure you have a backup configuration to file for safe keeping. A factory reset maybe needed.
dbnorton wrote:
I really hope they are able to fix this soon. I really don't want to have to completely factory reset my router!! I have a lot of home automation stuff that would all have to be touched. Most of those devices had static IP's setup. This is like a perfect storm for me as I lost a hard drive on one of my PC's that had my backup on it and now its gone! I even nmap'd the router IP and only 2 ports are showing open ports 53 and 5000. This really sucks!
ecw
May 08, 2022Guide
My Orbi login bombed out today (05/08/2022) as well. I have an Android w/o zero updates recently. I can't log into it via the browser on my desktop nor the app on my phone.
Did NetGear push out an update today or recently that might have caused this? I can't log in to check to see if it was updated obviously.
E
