dbnorton
May 08, 2022Tutor
I really hope they are able to fix this soon...
I really hope they are able to fix this soon. I really don't want to have to completely factory reset my router!! I have a lot of home automation stuff that would all have to be touched. Most of t...
retromad
May 09, 2022Star
Just a suggestion here, maybe netgear could backup the devices it is updating prior to pushing out updates? If a hard reset is part of the recommended actions post update, netgear should be allowing the schedule of said updates. Alternatively, I am sure most users would not mind providing a google drive or other cloud storage area for storing a file that could save them 3 hours of reconfig.
ecw
May 09, 2022Guide
I haven't performed the factory reset yet as I can't do that in the middle of the work day. Once I 30/30/30 reset it later, I will post the results.
I do have a family member that has the same model of Orbi but is running 4.6.5.14. that previous version is stable. The hot mess started when 4.6.8.2 was forced/auto updates to my router.
- FURRYe38May 09, 2022Guru - Experienced User
You might try re-loading the v.2 FW manually on the RBS then RBR lastly and see if this also helps clear out this problem as well. I normally manually update. AU seems to cause more problems than it's worth. Hoping NG will get this fixed.
