Allen090
Aug 03, 2026Aspirant
I recently upgraded to the AT&T fiber 1G plan
Hello, looking for some advice. I recently upgraded to the AT&T fiber 1G plan, I had Spectrum broadband 1G plan prior to changing, and was consistently getting 700 - 800 speed, while using the Orbi ...
Aug 04, 2026Guru - Experienced User
Due to the limitation of the WAN and LAN ports on the 760 series system of 1000Mpbs, you'll never see any speeds much over 900Mpbs on that system.
If your ISP has support for speeds beyond 1000Mpbs, then you'll need a Orbi system that has WAN and LAN port speeds that support beyond 1000Mbps.
Orbi models AXE 960 series start at having both WAN and LAN ports that support speeds past 1000Mbps. Orbi BE series all have WAN and LAN ports that support speeds past 1000Mpbs.
