ultradeepfiled
Oct 31, 2022Aspirant
I still can’t access to my router(RBR850)
Hello. I can’t access to my router either from Orbi app or web interface(192.168.1.1) at least 2-3 times a day, though internet works fine. Every time it happens, I have to manually reboot the rou...
- Oct 31, 2022
Yes I would factory reset and setup from scratch using a wired PC and web browser. You might even do this with the RBR off line and turn OFF any RBS. Setup again using same SSID name and PW. Use MS Edge or Firefox for this.
I recommend changing the default IP address pool range on the RBR to 192.168.1.100 to .150 or .200 depending upon how many devices you have all connected. I have around 35 here and use .150.
When you apply the change the router should reboot. Reconnect the RBR to the ISP modem.
ultradeepfiled
Thanks for your help.
I have tried several quality LAN cables, but ended in no luck.
Factory reset was done once about 6 months ago when I first noticed this issue.
I have manually updated to this version of firmware by connecting to web interface(192.168.1.1) from my ipad.
I didn’t performed factory reset at that time cuz I thought the new firmware would fix my problem.
Do you think it is worth trying another factory reset from PC wired directly to my router, despite all the tedious works of re-configuring the whole setting of my router?
Thanks.
Oct 31, 2022Guru - Experienced User
- ultradeepfiledNov 17, 2022Aspirant
I'm sorry for being late for updating my status.
I've been kind of busy for past couple of weeks.
It's been about a week since I performed factory reset and set up from scratch with wired laptop.
Until now, there is no problem found with accessing my router either via orbi app or web.
I think your suggestion did work.
One thing I don't like is the seal value on router debug page.
I read the post saying that I can check if the fix really worked or not by verifying seal value is '-2' on router debug page.
I don't know what the 'seaI value' exactly means, and how it works.
But I can see the seal value is still marked as '-0', not '-2'.
Anyway, my access problem seems to be gone for the time being.
Thanks for your suggestion. I really appreciate that.
- FURRYe38Nov 18, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
