JimmyBSwe
Dec 26, 2023Aspirant
I was looking for info about if I can use two Orbi RBS350 satellites to an Orbi RBR750 router
Hi!
I just saw this chatt when I was looking for info about if I can use two Orbi RBS350 satellites to an Orbi RBR750 router, I chatted with Netgear and got the answer that it is not possible, but ...
- Jan 28, 2024
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
JimmyBSwe
Jan 08, 2024Aspirant
Sorry for all the questions but it's getting closer to change my system now and wondering if there is a guide on how and in which order I shall install the new system.
So I'm going to replace my rbr350 router with an rbr750 router and use my rbr350-router as an AP, and that my current satellites will continue to be used, I know which FW I'm going to use, but does the FW have to be installed on the AP as well or does it follow the new router's settings?
- FURRYe38Jan 08, 2024Guru - Experienced User
If your going to connect a 750 series RBR and have the 350 RBS connect to it, then you'll need to keep with the following version of FW on the 750 and the 350 units:
If your going to migrate the 350 RBS with the RBR350 then you'll need to keep with the 350 series FW for that system while in AP mode:
Then you can update the RBR750 to v7 FW if you don't have any plans on connecting the 350 series RBS:
- JimmyBSweJan 09, 2024Aspirant
Ok, do I understand you correct now? 😇
Can I continue to have the satellites wireless linked to the RBR350-router even though I turn it into an AP as long as the RBR350-router are wired as an AP to my new RBR750 router?
And do I continue to use the same FW-version that I have now on my RBK353-kit (RBR350 FW version: v4.4.1.29_3.10.80 and RBS350 FW version: v4.4.1.29) and at the same time use the latest FW-version on my new RBR750-router? (FW-version 7.2.6.21)
WOW, how little I understand of this, is much more to think about than I thought from the beginning.! 😅
Cheers!
- FURRYe38Jan 09, 2024Guru - Experienced User
Yes to all.
Ya, it's crazy. I think you understand. 😉
