JimmyBSwe
Dec 26, 2023Aspirant
I was looking for info about if I can use two Orbi RBS350 satellites to an Orbi RBR750 router
Hi!
I just saw this chatt when I was looking for info about if I can use two Orbi RBS350 satellites to an Orbi RBR750 router, I chatted with Netgear and got the answer that it is not possible, but ...
- Jan 28, 2024
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
JimmyBSwe
Jan 08, 2024Aspirant
Sorry for all the questions but it's getting closer to change my system now and wondering if there is a guide on how and in which order I shall install the new system.
So I'm going to replace my rbr350 router with an rbr750 router and use my rbr350-router as an AP, and that my current satellites will continue to be used, I know which FW I'm going to use, but does the FW have to be installed on the AP as well or does it follow the new router's settings?
Jan 08, 2024Guru - Experienced User
If your going to connect a 750 series RBR and have the 350 RBS connect to it, then you'll need to keep with the following version of FW on the 750 and the 350 units:
If your going to migrate the 350 RBS with the RBR350 then you'll need to keep with the 350 series FW for that system while in AP mode:
Then you can update the RBR750 to v7 FW if you don't have any plans on connecting the 350 series RBS:
- JimmyBSweJan 09, 2024Aspirant
Ok, do I understand you correct now? 😇
Can I continue to have the satellites wireless linked to the RBR350-router even though I turn it into an AP as long as the RBR350-router are wired as an AP to my new RBR750 router?
And do I continue to use the same FW-version that I have now on my RBK353-kit (RBR350 FW version: v4.4.1.29_3.10.80 and RBS350 FW version: v4.4.1.29) and at the same time use the latest FW-version on my new RBR750-router? (FW-version 7.2.6.21)
WOW, how little I understand of this, is much more to think about than I thought from the beginning.! 😅
Cheers!
- FURRYe38Jan 09, 2024Guru - Experienced User
Yes to all.
Ya, it's crazy. I think you understand. 😉
Ok, nice.!!
But will it still be one network? It's not going to be two networks as the firmware is different on the different devices and since the satellites still are connected to the RBR350 AP, I mean won't the RBR750 be "stand alone" in its own wireless connection and the RBK350-kit be "stand alone" in its own network?
I think I'm making this more advanced than it is in my head, sorry for the million questions.!🤔🙂
