JimmyBSwe
Dec 26, 2023Aspirant
I was looking for info about if I can use two Orbi RBS350 satellites to an Orbi RBR750 router
Hi!
I just saw this chatt when I was looking for info about if I can use two Orbi RBS350 satellites to an Orbi RBR750 router, I chatted with Netgear and got the answer that it is not possible, but ...
- Jan 28, 2024
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Jan 24, 2024Guru - Experienced User
What browser are you using? Try MS Edge or Firefox or Opera.
Choose the Accept or any continue buttons seen for the private message. It's ok to continue here.
You need to update the RBS first, then RBR lastly in this order.
JimmyBSwe
Jan 24, 2024Aspirant
Ok, thanks.! The router upgraded to FW v4.6.14.3 automatically when I installed it from the box.. So I now have a network cable from the router to a switch and my computer on one port and one satellite on one port.. Is it possible to install FW on the satellite that way? If I'm right the computer and the satellite can communicate without that the router getting involved that way, right?
