JimmyBSwe
Dec 26, 2023Aspirant
I was looking for info about if I can use two Orbi RBS350 satellites to an Orbi RBR750 router
Hi!
I just saw this chatt when I was looking for info about if I can use two Orbi RBS350 satellites to an Orbi RBR750 router, I chatted with Netgear and got the answer that it is not possible, but ...
- Jan 28, 2024
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
JimmyBSwe
Jan 28, 2024Aspirant
Everything works fine, now I just have to convert the router to AP.!😀
- FURRYe38Jan 28, 2024Guru - Experienced User
Enjoy. 📡
