trmeadows
May 12, 2022Aspirant
Idoorbell Fon will not see the WiFi network on RBR850 Orbi.
I am able to connect via wired connection but the operation fails when attempting to switch to WIFI.
Mikey94025
May 13, 2022Hero
Try setting your CTS/RTS Threshold to 2347 to maximize compatibility with older wireless devices:
- Go to the web admin portal at http://orbilogin.com/
- Click to the Advanced tab, Advanced left menu, Wireless Settings
- Set CTS/RTS Threshold to 2347 for both 2.4hz and 5Ghz networks
- Press Apply
See if that helps. If problems still persist, next try disabling AX mode for the 2.4Ghz band:
- Go to http://orbilogin.com/
- Click to the Advanced tab, Setup left menu, Wireless Setup
- Uncheck "Enable 2.4G" under the top Enable AX section
- Press Apply
- trmeadowsMay 16, 2022Aspirant
Thanks for the suggestion, but it still did not see the WiFi network.
