quanah
Oct 02, 2023Aspirant
I'm facing an issue with connections constantly dropping on multiple systems
After upgrading my RBR and RBS850 to v7.2.6.21, I'm facing an issue with connections constantly dropping on multiple systems, even systems directly plugged into the ethernet port of the RBR, so it's ...
Oct 03, 2023Guru - Experienced User
How was the system updated? Via AU or manually by updating the RBS FIRST then RBR lastly?
Did you power OFF everything for 1 minute then back ON after FW was updated?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
How many RBS are deployed?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰️
Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?
Armor, Smart Parental Controls or Circle, Traffic Meter.
How was the factory reset performed?
A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
https://kb.netgear.com/25722/How-do-I-reserve-an-IP-address-on-my-NETGEAR-router
I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 15 seconds then release.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://kb.netgear.com/000062081/How-do-I-erase-the-configuration-settings-on-my-Orbi-WiFi-System
quanah wrote:
After upgrading my RBR and RBS850 to v7.2.6.21, I'm facing an issue with connections constantly dropping on multiple systems, even systems directly plugged into the ethernet port of the RBR, so it's not an issue with the wireless configuration. Tried a factory reset and now things are even worse. Not sure where to go from here.
