quanah
Oct 02, 2023Aspirant
I'm facing an issue with connections constantly dropping on multiple systems
After upgrading my RBR and RBS850 to v7.2.6.21, I'm facing an issue with connections constantly dropping on multiple systems, even systems directly plugged into the ethernet port of the RBR, so it's ...
quanah
Oct 05, 2023Aspirant
Again, you've failed to indicate how this can be remotely relevant. The issue happens between systems that only send traffic across the RBR's hard wired ethernet. The cable modem is not involved in that traffic whatsoever. However it is an UBEE, model # UBC1322
Does the front LED on the RBR turn on PINK or WHITE any?
This is not a coherent sentence, so I'm not sure what you're asking. When the RBR powers up, the LED is WHITE until it finishes booting, and then it turns BLUE.
- FURRYe38Oct 05, 2023Guru - Experienced User
It's very relevant. We need to establish if the ISP modem/ONT has built in router and wifi. As these can and do cause problems. And from the model you have, it does have a bulit in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...Does the front LED on the RBR turn on PINK or WHITE any when this problem appears for you and you have problems?
- quanahOct 09, 2023Aspirant
https://kb.netgear.com/30187/How-to-fix-issues-with-Double-NATOnce again.. I've *never* had any issues with this setup UNTIL I upgraded to *this specific* firmware. Again, the traffic over the LAN in no way involves the cable modem.
I already answered this. Other than the bootup sequence, the light stays off.
Additionally, ever since this firmware upgrade, all my video calls for work have started having significant issues (to a wired device, so it's not the wireless).
Given the responses so far however, I've little faith I'll get anything useful from this forum.
- FURRYe38Oct 09, 2023Guru - Experienced User
You need to contact NG support then since you don't seem willing to let us help you out and give feedback to questions presented.
https://my.netgear.com/support/contact.aspx
https://www.netgear.com/support/contact.aspxGood Luck.
