nthstar
Jul 08, 2022Aspirant
I'm hoping to get some help with this topic as well please
I'm hoping to get some help with this topic as well please. I have 1 X RBR850 and 1 X RBS850 (connected via ethernet to the RBR) and positioned ~30ft from the RBR unit. Devices are in Router mode....
Jul 09, 2022Guru - Experienced User
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings
Also try turning down the power output of the RBRs wifi radios from 100% to 25% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
nthstar
Jul 12, 2022Aspirant
- DrayTek Vigor 2865
- roughly 350sq ft
- Under the web portal for "wireless settings (general) it says:
-- Region Australia
-- 2.4G Channel Auto (2)
-- 2.4G Wireless mode: Up to 1147 Mbps
-- 5G Channel 36 + 40 + 44 + 48(P)
-- 5G Wireless mode: Up to 2402 Mbps
- I can see 16 when on the Orbi Wifi App (in Wifi Analytics) and 38 other SSIDs when I search for WiFi Networks on my MAC laptop
- Under "2.4GH" it is a tick box saying "Enable 20/40 MHz Coexistence". Are you saying I should untick this to make it default to 40Mhz?
- Preamble mode for 2.4 and 5gz are both sent to "Automatic"
- I cannot just turn the power down for the Router. I have to turn down the Signal for 2.4 or 5Ghz.
- I've moved both down to 50% to review how that works
The change I have made is to reduce the 2.4 and 5Ghz signals from 100% to 50%, so I'll see how that goes over the next few days and report back.
Thanks,
Andrew
- FURRYe38Jul 12, 2022Guru - Experienced User
What mode is this working in? Router or Modem mode?
https://www.draytek.com/products/vigor2865/
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopWhat is the size of your home? Sq Ft?
- roughly 350sq ft
350sq ft? <IF this is right, you don't need any RBS. Only the RBR will be needed. The size of home would be too small for RBS.
-- Region Australia
-- 2.4G Channel Auto (2) <Try channels 1, 6 or 11.
Any Wifi Neighbors near by? If so, how many?- I can see 16 when on the Orbi Wifi App (in Wifi Analytics) and 38 other SSIDs when I search for WiFi Networks on my MAC laptop
<You maybe in a wifi congested area.
- Under "2.4GH" it is a tick box saying "Enable 20/40 MHz Coexistence". Are you saying I should untick this to make it default to 40Mhz? <Lets leave this enabled for now.
- I've moved both down to 50% to review how that works< That what was meant my turning down the transmit power.
- nthstarJul 12, 2022AspirantThanks for the reply and continued help!
1. I don't have login access to the DrayTek, but it assigns all IP addresses on the network and passes bandwidth through to a Switch which connects 8 x Zoom TVs to the internet.
(The Orbi is connected to a port in the Switch and not an ethernet port in the DrayTek - do you think that needs to change?)
2. The DrayTek doesn't have any wifi turned on. Only the Orbit is supporting our wifi network
3. When I first got the Orbit I put it in AP mode but we lost the Guest network, and I had constant drop outs of wifi on devices.
Because of this I put it back into Router mode as I felt it was the firmware not able to handle things. I don't believe my setup is too bad (I know it's definitely not best practice..). It just means devices connected to the DrayTek through our Switch are on 10.x.x.x IPs (all ethernet devices) and all other devices on Wifi via the Orbit are on 192.x.x.x IPs. Everything is cloud based so having 2 IPs isn't breaking anything for us. Unless you think the Orbi is getting confused by this?
I suppose now that I'm getting devices dropping again and the Orbi is in Router mode it shows it wasn't the AP mode setting that wasn't working originally.
4. Sorry, I was trying to convert square metres to ft. We're roughly 4,800 square ft (~450 square metres). I assumed 1 X Satellite was needed just to help support 100 devices we have connected
5. I'll change the 2.4 channel tomorrow, thanks for the recommendation
6. I agree we have a lot of other wifi noise. I assume we'd need a much more expensive, enterprise grade AP to get better cut through đ
7. Re strength. I thought I'd be able to turn down the Router strength as maybe that was overlapping the Satellite device. I'll see how we go with just that changed over the next few days.
Thanks!- FURRYe38Jul 12, 2022Guru - Experienced User
Ok, thanks for the clarification. All makes better sense now.
See how it runs at 50%. Ya there is some noise going on there. Definitely change the 2.4Ghz channel.
