facest
Nov 29, 2023Tutor
I'm struggling with this with a new RBR853 kit
I'm struggling with this with a new RBR853 kit, I can ping the satellite IP but I'm not able to access the web interface anyway.
I've tried resetting them, tried wired backhaul, tried connectin...
- Dec 04, 2023
I ended up resolving this myself using nmrpflash after searching for info about how to fix a bricked device, even though mine weren't exactly bricked.
After this I had to move the satellites closer to the router and power them on, and after a few reboots they were up and running with the sync error gone and web interfaces accessible.
PS D:\Applications> .\nmrpflash.exe -L
net15 192.168.1.107 22:22:22:22:22:22 (Wi-Fi)
net13 192.168.1.254 33:33:33:33:33:33 (Ethernet) <--- use this interface
PS D:\Applications> .\nmrpflash.exe -i net13 -f .\RBS850-V7.2.6.21.chk
Waiting for Ethernet connection (Ctrl-C to skip).
Warning: IP address marked as deprecated.
Advertising NMRP server on net13 ... /
Received configuration request from 44:44:44:44:44:44.
Sending configuration: 10.164.183.253/24.
Received upload request: filename 'firmware'.
Uploading RBS850-V7.2.6.21.chk ... Warning: TFTP block rollover. Upload might fail!
OK (38540186 b)
Waiting for remote to respond.
Remote finished. Closing connection.
Reboot your device now.Netgear's manual flash instructions weren't helpful in this situation and I think they should extend it to include nmrpflash - it's an easy process... if you know it's something to try.
Going around in circles with support re-doing the initial setup steps and hoping it'd do something different really isn't a good experience, especially when it was clear this was an issue with with the satellites on their own.
Nov 29, 2023Guru - Experienced User
What Firmware version is currently loaded? Be sure that FW on the RBS is same as whats loaded on the RBR.
RBS need to be updated first before the RBR is.
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR📡 and RBS🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️
facest
Nov 29, 2023Tutor
The router says V7.2.6.21_5.0.20, I can't tell what the satellites are on because they're not reachable and the field is blank when looking from the router. There's only one firmware update button in the app - not one for the router and a separate one for the satellites - are you saying this is the wrong way to update and is known to break the satellites?
There's no ISP modem, the Orbi is connected directly to the ISP and has PPPoE configured for the WAN. Internet works fine when connected to the router. It's a small home, but I've tried the satellites both close to the router and over 30ft from it with no difference and also tried wired backhaul as mentioned - they show up on the routers web interface as wired, but are still unreachable.
- FURRYe38Nov 29, 2023Guru - Experienced User
Yes, RBS need upating First, then RBR lastly.
Can you ethernet connect the RBS to the back of the RBR and see if the RBS appear on the RBRs web page at all with a IP address?
- facestNov 29, 2023Tutor
They appear on the RBR with an IP address if I use wireless backhaul or wired backhaul. I feel like I'm repeating myself, I've mentioned this in both previous messages.
The satellites show up on the RBR but the IP address isn't reachable (other than ping) to be able to manually update them.
Using the IP address for the RBS, can you put that into a web browser to see if you can access the RBS web pages?
If you can try logging in using the RBR log in info or maybe admin and password.
If you can get in check the FW version, if they are not updated and behind, manually update them by sending the FW file to the RBS web page there using the web browser. Unpack the .zip file.
