facest
Nov 29, 2023Tutor
I'm struggling with this with a new RBR853 kit
I'm struggling with this with a new RBR853 kit, I can ping the satellite IP but I'm not able to access the web interface anyway.
I've tried resetting them, tried wired backhaul, tried connectin...
- Dec 04, 2023
I ended up resolving this myself using nmrpflash after searching for info about how to fix a bricked device, even though mine weren't exactly bricked.
After this I had to move the satellites closer to the router and power them on, and after a few reboots they were up and running with the sync error gone and web interfaces accessible.
PS D:\Applications> .\nmrpflash.exe -L
net15 192.168.1.107 22:22:22:22:22:22 (Wi-Fi)
net13 192.168.1.254 33:33:33:33:33:33 (Ethernet) <--- use this interface
PS D:\Applications> .\nmrpflash.exe -i net13 -f .\RBS850-V7.2.6.21.chk
Waiting for Ethernet connection (Ctrl-C to skip).
Warning: IP address marked as deprecated.
Advertising NMRP server on net13 ... /
Received configuration request from 44:44:44:44:44:44.
Sending configuration: 10.164.183.253/24.
Received upload request: filename 'firmware'.
Uploading RBS850-V7.2.6.21.chk ... Warning: TFTP block rollover. Upload might fail!
OK (38540186 b)
Waiting for remote to respond.
Remote finished. Closing connection.
Reboot your device now.Netgear's manual flash instructions weren't helpful in this situation and I think they should extend it to include nmrpflash - it's an easy process... if you know it's something to try.
Going around in circles with support re-doing the initial setup steps and hoping it'd do something different really isn't a good experience, especially when it was clear this was an issue with with the satellites on their own.
