altjx
Jul 07, 2022Tutor
Impossible to disable 5ghz band? Trying to connect Nest Connect and Nest X Yale Lock
I have just purchased a Nest Connect and Nest x Yale Lock and, unfortunately, most of the process has been extremely painful. For one, I have read in several places that the Nest Connect doesn't "wor...
CrimpOn
Jul 07, 2022Guru - Experienced User
No. It is not possible to disable the 5Ghz band.
Which checkbox is this?
