chucklaurel
Oct 29, 2020Follower
input voltage of Power Adapter for Orbi AX6000 (RBK854)
Can I buy thie Orbi WiFi 6 AX6000 (RBK854) in the U.S. w/ a Power Adapter 100-240V to allow me to use in the Philippines where our voltage is 220V?
1 Reply
If the power adapter truly is 100-240v compatible, then it should work fine. you might just need a plug adapter.
I don't have one to look at to confirm.
