mattshandera
Sep 20, 2020Aspirant
Intel AC 3168 WiFi Adapter Intermittent connection to Orbi Network
Team, TL'DR: Two identical gaming Cyberpower gaming PCs (purchased this year) both of which are having intermittent connections issues to the Orbi network. They were rock-solid UNTIL Orbo was i...
Mikey94025
Sep 27, 2020Hero
FURRYe38 wrote:What happens if you disable AX Mode. Then turn AX mode back on?
Try changing CTS to 2347 under Advanced Tab/Advanced Settings/Wireless Settings.
What were the results of changing CTS/RTS to 2347 and/or toggling the AX mode for the 2.4Ghz band (and then also try 5Ghz band)? These two configuration options seem to be the best way to improve compatibility with older wireless devices. Yes, your gaming PC is not that old but these options may still affect (i.e., improve) your problemmatic Intel wireless adapter behavior.
Sep 27, 2020Guru - Experienced User
I presume you directed this to the OP?
