premier87
Mar 03, 2022Aspirant
Intermittent connectivity in a business setting
I recently purchase the RBK753S Router/2 satellite system from costco, for my wifes Therapy practice. There are 8 offices/therapists, and two of them upstairs are experiencing slow connectivity and o...
Mar 03, 2022Guru - Experienced User
any chance you have coax ran through the home?
or reasonably updated wiring?
Reason I ask is you could use moca adapters (ethernet over coax) or powerline adapters.
Stone is amazing at blocking wifi. And the satellites still need a decent signal to connect back to the primary router on.
If its being blocked, they're going to struggle. But they do support a wired backhaul. that'd be where the moca or powerline adapters could come in.
Sadly, the older homes with stone/plaster lathe struggle with mesh systems unless they're hardwired in.
