SilverQ
Mar 16, 2023Aspirant
Intermittent disconnects from internet Orbi 750
CBR750 with 2 satellites. Firmware v4.6.14.4. Last week I noticed that my iPad was losing connection to the WiFi network. I didn't seem to have any issues with my laptops (MacBook Pro and Air) at ...
Mar 16, 2023Guru - Experienced User
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰️
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Armor, Smart Parental Controls or Circle, Traffic Meter.
- SilverQMar 16, 2023Aspirant
Not sure if I made a mistake in the posting, but this is the cable modem version - Orbi CBR750.
At one point earlier this week, I noticed the UpStream light was flashing white, but that has since not reappeared since I did the hard factory reset.
I'm having the problem with and without the LAN connected, so I don't believe the cable is the issue - tbh, the cable wasn't connected beforehand, but I did the connection just to see if the issue was WiFi specific.
SqFt is around 1200, but two stories. I've had this set up since July of last year with no issues. I first noticed the problem Friday of last week. No additional devices were added to the network, nor am I aware of any anomalies associated with my equipment.
I live in a condo, so plenty of folks / networks around.
Upstairs is both the main unit and one satellite, about 45 feet apart and in LOS, while the second satellite is downstairs and definitely 30 feet away.
2.4 was set on auto, but I use 5 for all of my primary devices and that was already set on 48.
I did not have any of the services mentioned turned on.
I'm having issues in all areas of the condo, including when connected via ethernet, so I don't believe this is a WiFi specific problem.
- CrimpOnMar 16, 2023Guru - Experienced User
There have been posts recently about the CBR750 and certain cable providers. Could you please identify which cable company you are using?
Thanks
Cox communications
- FURRYe38Mar 17, 2023Guru - Experienced User
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-routerHave the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html- SilverQMar 19, 2023Aspirant
Copy and Paste seems to really mess up the formatting, so I've attached a screen grab of the Cable Connection here.
