msinex
Jul 27, 2020Apprentice
Intermittent DNS Errors and WiFi Issues
I have had the Orbi AX6000 for a few months now. While there are many things I love about it (great wifi coverage, great speed, looks nice, software, ease of setup, etc.), there are two very frustra...
Mikey94025
Jan 24, 2021Hero
msinex wrote:Did DNS_PROBE_FAIL and Mikey94025 use the beta FW build that Ace321 is utilizing or just the most recent one you can officially get off of Netgear?
I did not use a Beta build nor am I working with Netgear for my issues (I have easy workarounds or not serious enough to spend my time on it). I'm using the latest available for public download: V3.2.17.12_1.4.14.
DNS_PROBE_FAIL
Jan 27, 2021Luminary
I FOUND THE PERMANENT FIX!!!!
What I did was boxed up my $1000 Orbi system and returned it, then reinstalled my older RBR50 / AC3000 system with the same configuration on our network and boom! No DNS issues, errors or device timeouts and I don't even have to enable IPv6 for it to work!
This is an epic fail from Netgear. Total lack of ownership of their issues at the expense of the consumer. I wish you all luck but I'm setting sail for smoother waters elsewhere.
I'm going to buy the Asus WiFi6 mesh solution and never look back.
- FURRYe38Jan 27, 2021Guru - Experienced User
Good Luck.
Mines working with or with out IPv6.
