msinex
Jul 26, 2020Apprentice
Intermittent DNS Errors and WiFi Issues
I have had the Orbi AX6000 for a few months now. While there are many things I love about it (great wifi coverage, great speed, looks nice, software, ease of setup, etc.), there are two very frustra...
lof
Mar 27, 2021Guide
Have also had varied experiences here. I used the Velop MX5300 system and that had major problems with the one node on wireless completely not accepted connections from WiFi devices, Nest WiFi was okay but compared to the AX systems the speeds were quite substantially slower. In terms of WiFi 6 mesh it seems there isn't quite the amount of avaialble options yet as there has been with WiFi 5.
lof
Mar 28, 2021Guide
Updated manually to the latest firmware update and the issue seems to still persist. Spoke to Netgear support and so far the agent I spoke to said they are completely unaware of this entire issue. Had completely no WiFi access on some devices this morning either.
- tak1313Mar 28, 2021Luminary
May not be anything, but are you using ipv6?
- zapp7Mar 28, 2021StarThat's funny, because I've been speaking to support all week about this issue and even sent this forum thread to them.
Buying this Orbi was a huge mistake. I'll never buy Netgear again.- lofMar 28, 2021Guide
Buying this Orbi was a huge mistake. I'll never buy Netgear again.This is my issue. How could support possibly not know about this when there's numerous posts about it and god knows how many customers have raised it with them? This thread is now on 16 pages. Support should be acknowledging the issue and providing updates on a fix. They did say there was an update due in April but couldn't confirm whether this was due to be fixed or not which is shocking.
- FURRYe38Mar 28, 2021Guru - Experienced User
Did you try a factory reset and setup from scratch after updating FW?
lof wrote:Updated manually to the latest firmware update and the issue seems to still persist. Spoke to Netgear support and so far the agent I spoke to said they are completely unaware of this entire issue. Had completely no WiFi access on some devices this morning either.
- vajimMar 28, 2021Master
FURRYe38 wrote:Did you try a factory reset and setup from scratch after updating FW?
many have tried this.....it doesn't work
Manual resets tried here as well, this is happening to too many people across too many different ISPs and modem combinations for it to be a particular equipment or setup issue outside of the Orbi system.
- tak1313Mar 29, 2021Luminary
lof wrote:Spoke to Netgear support and so far the agent I spoke to said they are completely unaware of this entire issue.
...it's in the script...
I HATE when companies feign ignorance about known issues - it's outright lying.
- ValidusMar 29, 2021Luminary
This is still occurring for me, months later.
However, I believe I know the problem and possible solutions.
In regards to my intermittent DNS error message. I'm using the "NETGEAR Orbi RBK853 AX6000 Tri-band WiFi 6 Mesh System- 3 pack". Still might be different for others?
1) The Netgear Orbi AX series has builtin NETGEAR Armor powered by Bitdefender. Which is great if you wish to use that, but becomes a problem if you don't. I have Kaspersky Internet Security already and don't need it. This feature seems to call out and loop around the DNS request, to check with Netgear Armor for malicious and phishing URLs, etc. Can it not do that, if an opt-out is offered or if it's disabled under the router admin? That loop around causes a DNS delay, even if Netgear Armor is disabled by the looks?
2) A single DNS failure call from a webpage, will be displayed over top, even if the rest of the webpage is loading fine.
As mentioned before...
For even this website: https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
It will sometime gives a "DNS_PROBE_FINISHED_NXDOMAIN" message.
Yet I've narrowed it down to a possible URL it's attempting to load with the webpage:
https://cloud.github.com/downloads/lafeber/world-flags-sprite/flags32.css
Press F12 on your web-browser and look under the networking, refresh the page with CTRL + F5.
You might notice a single or multiple files showing (failed) net::ERR_NAME_NOT_RESOLVED.
Go to that link directly and you will get the message:
Hmmm… can't reach this page. Check if there is a typo.
If spelling is correct, try running Windows Network Diagnostics.
DNS_PROBE_FINISHED_NXDOMAINThat's the actual valid error.
However, it doesn't matter for the rest of the website that it broke. The rest should load fine and work normally. On almost every other routers and meshes out there that is ignored and skipped over, but with the NetGear Orbi AX it displays that message over top of the entire webpage for at least a few seconds or has you needing to refresh the page to display it.
This is still occurring for me, months later. However, I believe I know the problem and possible solutions.
2) A single DNS failure call from a webpage, will be displayed over top, even if the rest of the webpage is loading fine. As mentioned before...
Press F12 on your web-browser and look under the networking, refresh the page with CTRL + F5. You might notice a single or multiple files showing (failed) net::ERR_NAME_NOT_RESOLVED.
"Hmmm… can't reach this page. Check if there is a typo.
DNS_PROBE_FINISHED_NXDOMAIN"That's the actual valid error.
However, it doesn't matter for the rest of the website that it broke. The rest should load fine and work normally. On other routers and meshes out there that is ignored and skipped over, but with the NetGear Orbi AX it displays that message over top of the entire webpage for at least a few seconds or has you needing to refresh the page to display it.
Why is it removing my post? Too big, considered as spam or contains the valid information to fix this problem? Can mods of the website still see it at least?
