msinex
Jul 26, 2020Apprentice
Intermittent DNS Errors and WiFi Issues
I have had the Orbi AX6000 for a few months now. While there are many things I love about it (great wifi coverage, great speed, looks nice, software, ease of setup, etc.), there are two very frustra...
RockGuitarist1
May 14, 2021Star
I'm not sure what to do at this point. Using it as an AP just makes it a very expensive AP. I'd much rather just have a working mesh network instead of having a more advanced configuration.
energie
May 14, 2021Luminary
Yeah, that is exactly what the Orbi AX is. A very expensive AP. I personally would also stay away from Netgear if there would be a better solution. I feel it is very bad of Netgear to ignore its customers and this problem, which is pretty much affecting everyone. I just think the majority isn't aware. Meanwhile the support department is busy keeping customers busy by resetting their routers / or pointing the problem to something else - blaming the ISP router/modem is also a populair thing / and swapping (RMA) the device until the 90 day support window runs out. Meanwhile the main issue is with the Netgear firmware. For this reason alone I would skip Netgear and all of its products - and just blacklist this entire company.
So you can try out some other brand. Just know that as an AP the Orbi AX works pretty good.
