msinex
Jul 26, 2020Apprentice
Intermittent DNS Errors and WiFi Issues
I have had the Orbi AX6000 for a few months now. While there are many things I love about it (great wifi coverage, great speed, looks nice, software, ease of setup, etc.), there are two very frustra...
Amcbroom81
Aug 02, 2021Tutor
Just downloaded the new beta firmware for my orbi RBR850. Can someone point me to the correct way to upload and install these software updates? I want to do it right and not mess things up. Thanks for the help!
Mstrbig
Aug 03, 2021Master
Amcbroom81 wrote:Just downloaded the new beta firmware for my orbi RBR850. Can someone point me to the correct way to upload and install these software updates? I want to do it right and not mess things up. Thanks for the help!
Manually update satellite firmware We recommend that you update your satellite’s firmware before you update the router’s firmware.
To manually update your satellite’s firmware:
1. Launch a web browser from a computer or mobile device that is connected to your
Orbi network.
2. Enter orbilogin.com.
A login window opens.
3. Enter the router admin user name and password.
The user name is admin. The password is the one that you specified the first time
that you logged in. The user name and password are case-sensitive.
The BASIC Home page displays.
4. Select ADVANCED > Administration > Firmware Update > Manual Update.
The Firmware Update page displays.
5. Select the check box next to your satellite’s model name.
If you have more than one satellite, only update one satellite at a time. You must wait
for the first satellite to finish updating before updating the next satellite.
6. Click the Update button.
Manage Your Network 82 User Manual
Orbi Whole Home Tri-Band Mesh WiFi 6 System
The Orbi satellite Firmware Update window opens.
7. If the browser ask you for the admin password, enter the same password that you
entered for the router.
8. Click the BROWSE button.
9. Locate and select the satellite firmware file that you downloaded.
The firmware file name ends in .img or .chk.
10. Click the UPLOAD button.
It takes a few minutes to complete the process.
11. After Orbi satellite finishes updating, select Status and double-check the firmware
version on the Status page.
The firmware on your Orbi satellite is updated.
Manually update router firmware We recommend that you update your router’s firmware after you update the satellite’s firmware.
WARNING: Make sure that your satellite completes its firmware update before you
update your router’s firmware.
To manually update your router’s firmware:
Orbi network.
3. Enter the admin user name and password.
5. Click the Browse button.
6. Locate and select the router firmware file you downloaded.
The firmware file name ends in .img.
7. Click the Upload button.
The firmware is updated.
- jdk1120Aug 03, 2021Apprentice
Hi, I've been having this intermittent disconnect issue with my brand new(!) RBR750 router with the latest firmware installed. Every 10 minutes or so, my connection cuts out for ~2 seconds and comes right back. So it doesn't boot me from my Zoom meeting, but rather a lag.
This forum tell me that this is a common problem... I've read through many pages of this forum and can I ask: has there been an agreed-upon solution to this issue? Would you recommend me returning the device since I'm still within my 3 month window?
Very disappointing as we've all paid a premium (relative to Google or Amazon mesh router) for a premium product...
- FURRYe38Aug 03, 2021Guru - Experienced User
jdk1120 wrote:Hi, I've been having this intermittent disconnect issue with my brand new(!) RBR750 router with the latest firmware installed. Every 10 minutes or so, my connection cuts out for ~2 seconds and comes right back. So it doesn't boot me from my Zoom meeting, but rather a lag.
I have firmware V4.6.3.7_2.0.49 for my RBR750 (RBK753S). I have Verizon Fios as my ISP but do not know the exact modem number.
Is the beta firmware being discussed an official one (albeit beta mode) from Netgear or a user-created program? I messaged Christian a few hours ago and hope to receive the beta firmware soon..
- Amcbroom81Aug 10, 2021TutorThanks for the help! Will follow these steps and hope my issues go away. Thanks again!
- FURRYe38Aug 11, 2021Guru - Experienced User
DNS issues are fixed in the beta FW.
Amcbroom81 wrote:
Thanks for the help! Will follow these steps and hope my issues go away. Thanks again!- TobamoryOct 15, 2021Tutor
Guys has this now been released as a proper fix ?
