msinex
Jul 26, 2020Apprentice
Intermittent DNS Errors and WiFi Issues
I have had the Orbi AX6000 for a few months now. While there are many things I love about it (great wifi coverage, great speed, looks nice, software, ease of setup, etc.), there are two very frustra...
Aug 03, 2021Guru - Experienced User
jdk1120 wrote:Hi, I've been having this intermittent disconnect issue with my brand new(!) RBR750 router with the latest firmware installed. Every 10 minutes or so, my connection cuts out for ~2 seconds and comes right back. So it doesn't boot me from my Zoom meeting, but rather a lag.
This forum tell me that this is a common problem... I've read through many pages of this forum and can I ask: has there been an agreed-upon solution to this issue? Would you recommend me returning the device since I'm still within my 3 month window?
Very disappointing as we've all paid a premium (relative to Google or Amazon mesh router) for a premium product...
jdk1120
Aug 03, 2021Apprentice
I have firmware V4.6.3.7_2.0.49 for my RBR750 (RBK753S). I have Verizon Fios as my ISP but do not know the exact modem number.
Is the beta firmware being discussed an official one (albeit beta mode) from Netgear or a user-created program? I messaged Christian a few hours ago and hope to receive the beta firmware soon..
- FURRYe38Aug 03, 2021Guru - Experienced User
v4 would have and has been reported as having the DNS fix included in this version.
If your on v4 then you'll not be able to try v3 official NG beta that was mentioned as v4 seems to prevent users from reverting back to v3.
Will need to check on your model # of the FIOS unit you have. Need to know if it has a built in router or not.
jdk1120 wrote:I have firmware V4.6.3.7_2.0.49 for my RBR750 (RBK753S). I have Verizon Fios as my ISP but do not know the exact modem number.
- jdk1120Aug 03, 2021Apprentice
I see, that's helpful to know. I just worked with an Orbi technician and she had me change some settings (DNS address to manual ones, 8.8.8.8 and 8.8.4.4; 2.4ghz channel to 11; Wan MTU size to 1492). She did acknowledge that many other users are experiencing the same issue as of late. Hopefully these setting channges do the trick...
Ok keep us posted.
Let us know the model# of the Verizon FIOS when you can.
jdk1120 wrote:I see, that's helpful to know. I just worked with an Orbi technician and she had me change some settings (DNS address to manual ones, 8.8.8.8 and 8.8.4.4; 2.4ghz channel to 11; Wan MTU size to 1492). She did acknowledge that many other users are experiencing the same issue as of late. Hopefully these setting channges do the trick...
