msinex
Jul 27, 2020Apprentice
Intermittent DNS Errors and WiFi Issues
I have had the Orbi AX6000 for a few months now. While there are many things I love about it (great wifi coverage, great speed, looks nice, software, ease of setup, etc.), there are two very frustra...
jdk1120
Aug 03, 2021Apprentice
I see, that's helpful to know. I just worked with an Orbi technician and she had me change some settings (DNS address to manual ones, 8.8.8.8 and 8.8.4.4; 2.4ghz channel to 11; Wan MTU size to 1492). She did acknowledge that many other users are experiencing the same issue as of late. Hopefully these setting channges do the trick...
Aug 03, 2021Guru - Experienced User
Ok keep us posted.
Let us know the model# of the Verizon FIOS when you can.
jdk1120 wrote:I see, that's helpful to know. I just worked with an Orbi technician and she had me change some settings (DNS address to manual ones, 8.8.8.8 and 8.8.4.4; 2.4ghz channel to 11; Wan MTU size to 1492). She did acknowledge that many other users are experiencing the same issue as of late. Hopefully these setting channges do the trick...
- jdk1120Aug 05, 2021Apprentice
This issue keeps coming back to me where my Zoom call freezes for 2 seconds every 15 minutes or so. It's not bad enough to prevent me from doing work, but bad enough to significantly affect it.
Has anyone had luck fixing the issue after exchanging it for a new router/satelite? If Netgear doesn't introduce a firmware patch, I might have to look into returning this router altogether :(
- FURRYe38Aug 05, 2021Guru - Experienced User
Please make a new post in regards to your Zoom app problems as this is something different from what this thread is referring too. Most of the DNS issues seen in this thread have been resolved.
Thank you.
jdk1120 wrote:This issue keeps coming back to me where my Zoom call freezes for 2 seconds every 15 minutes or so. It's not bad enough to prevent me from doing work, but bad enough to significantly affect it.
Sorry to cause confusion with the Zoom example. It is the whole internet that intermittently cuts out out with the satellite blinking white light and then coming back to lilfe. The symptom is exactly as others describe with the DNS issue. The issue is that I don't want to manually mess with the IPv6 settings on every device and hoping a solution through a firmware update will emerge (or an alternative fix)...
Lets make a new post and we'll help you out there.
Thank you.
jdk1120 wrote:Sorry to cause confusion with the Zoom example. It is the whole internet that intermittently cuts out out with the satellite blinking white light and then coming back to lilfe. The symptom is exactly as others describe with the DNS issue. The issue is that I don't want to manually mess with the IPv6 settings on every device and hoping a solution through a firmware update will emerge (or an alternative fix)...
- Mikey94025Aug 05, 2021Hero
Sorry, but no your symptoms are not the same so starting a new thread will help identify your particular issue and receive possible solutions. The DNS issue did not cause internet disconnects and only impacted DNS queries (mostly seen during web page browsing for new URL domain names, not recently cached). These browser queries would momentarily fail, then succeed shortly later when the browser automatically retried. The DNS issue would not cause Zoom cutouts because DNS lookups are not not involved once a Zoom call is setup. Therefore your issue of intermittent internet connetivity problems is different.
- rgautierAug 05, 2021Apprentice
Indeed - the DNS issues have been resolved, but the new firmware on my 750 has indeed started with some random reboots - yesterday during a Zoom meeting for me as well. Hope they find/fix the random reboot, but it is a new issue.
- FURRYe38Aug 06, 2021Guru - Experienced User
Please make a new post regarding these random boots that are seen on your system and we'll try to help you figure that out.
Thank you.
- bullm00nAug 06, 2021Virtuoso
You should return it. I would do that if I could. At some point this setup might become reliable if firmware can fix it, but my impression is something is badly wrong and not just the DNS issues. I had what seemed like fairly stable operation for a while, but now it's just one niggling issue after another to the point I may switch back to my old RBK53 setup and sell this at a loss. The RBK was not as fast, not as good of range, but far more reliable.
- TobamoryAug 06, 2021TutorSold my 853 ap mode fine otherwise overpriced junk
Settled on the Ubiquiti Alien mesh been bulletproof and supports 160mhz WiFi result
