msinex
Jul 27, 2020Apprentice
Intermittent DNS Errors and WiFi Issues
I have had the Orbi AX6000 for a few months now. While there are many things I love about it (great wifi coverage, great speed, looks nice, software, ease of setup, etc.), there are two very frustra...
bullm00n
Aug 06, 2021Virtuoso
jdk1120 wrote:This issue keeps coming back to me where my Zoom call freezes for 2 seconds every 15 minutes or so. It's not bad enough to prevent me from doing work, but bad enough to significantly affect it.
Has anyone had luck fixing the issue after exchanging it for a new router/satelite? If Netgear doesn't introduce a firmware patch, I might have to look into returning this router altogether :(
You should return it. I would do that if I could. At some point this setup might become reliable if firmware can fix it, but my impression is something is badly wrong and not just the DNS issues. I had what seemed like fairly stable operation for a while, but now it's just one niggling issue after another to the point I may switch back to my old RBK53 setup and sell this at a loss. The RBK was not as fast, not as good of range, but far more reliable.
Tobamory
Aug 06, 2021Tutor
Sold my 853 ap mode fine otherwise overpriced junk
Settled on the Ubiquiti Alien mesh been bulletproof and supports 160mhz WiFi result
