msinex
Jul 26, 2020Apprentice
Intermittent DNS Errors and WiFi Issues
I have had the Orbi AX6000 for a few months now. While there are many things I love about it (great wifi coverage, great speed, looks nice, software, ease of setup, etc.), there are two very frustra...
Oct 15, 2021Guru - Experienced User
I have not seen any DNS issues with v16 loaded on my 8 series Orbi nor v14 loaded on my 7 Series Orbi system.
Tobamory
Oct 16, 2021Tutor
Thanks, I’ll update them this weekend and see how it goes
- FURRYe38Oct 16, 2021Guru - Experienced User
If you do, I recommend that you apply manually, downloading the FW files, applying to the RBS first, then RBR lastly. After the FW is sent and units are back to ready. Power OFF the ISP modem/ ONT and RBR and RBS for a good 5 minutes, then back on with the ISP device, RBR then RBS.
See how it goes.
Tobamory wrote:
Thanks, I’ll update them this weekend and see how it goes - Mikey94025Oct 16, 2021Hero
Same here. My RBR850 system auto-updated to V4.6.3.16 a few weeks ago and I've not seen any of the DNS issues that had frequently appeared to me (until I installed the V3 beta with the fix).
I've also fortunately not had any issues with V4, despite holding back earlier because of problems posted in this forum.
- filmnikonOct 27, 2021Aspirant
Mikey94025 wrote:Same here. My RBR850 system auto-updated to V4.6.3.16 a few weeks ago and I've not seen any of the DNS issues that had frequently appeared to me (until I installed the V3 beta with the fix).
Okay so since I have also updated to V4.6.3.16, and I am still seeing DNS issue, I guess this means that the fix is not in this version? Can anyone confirm?
- GoldenRetroGameOct 27, 2021Apprentice
Yup. I had the DNS issues with the latest firmware.
- ValidusOct 27, 2021Luminary
I had this issue a lot on older firmware, the latest was a lot better and resolved it for a while.
I noticed it starting to reoccur again after 3 weeks to a month usage. Yet if you go under the admin and reboot it, seems to go back to running fine for a while yet again. Perhaps it's either a memory leak or occurs when multiple devices are attempting to connect? I know that rebooting would disconnect the wifi devices as well. The DNS errors seems to happen on a redirect, like when logging in or out of a website. Quickly refreshs and works fine.
I haven't seen the DNS issue again yet, since the last reboot.
Suggest updating to the latest firmware, rebooting if it happens again and then checking how long it takes to happen again (if it does or not).
- FURRYe38Oct 28, 2021Guru - Experienced User
No DNS issues here since putting my 8 series system back on line last Satuarday on v16 FW.
filmnikon wrote:Okay so since I have also updated to V4.6.3.16, and I am still seeing DNS issue, I guess this means that the fix is not in this version? Can anyone confirm?
