amenic
Sep 17, 2020Apprentice
Intermittent DNS lookup failures on RBR850
Intermittent DNS lookup failures RBR850 I've been using the Orbi RBR850 for several months now and I'm constantly having issues with DNS that I've NEVER experienced with any other router I've ever u...
Sep 17, 2020Guru - Experienced User
Are you using custom DNS addresses or letting the RBR auto detect DNS from your ISP?
90day warranty is mostly industry wide.
amenic
This isn't the problem. The modem is a 'dumb' modem, doesn't route, dhcp, dns etc.
Custom, using openDNS as mentioned (was using the same service on my old netgear router I upgraded from and the same modem and never had this problem)
No factory reset yet. The problem is annoying but this MOSTLY works.
- Mikey94025Sep 17, 2020Hero
This has been previously reported and plaguing other Orbi AX customers. IMO it is not something particularly wrong with your hardware unit and a problem in the latest firmware.
- https://community.netgear.com/t5/Orbi-AX/RBR850-frequently-issuing-DNS-REFUSED-responses/m-p/1926207/highlight/true#M4399
- https://community.netgear.com/t5/Orbi-AX/Intermittent-DNS-Errors-and-WiFi-Issues/m-p/1950768#M5458
I see it very often while web browsing in my browser, where it quickly refreshes and tries again to display the page. I also see it exhibited when I go a URL bookmark for this Negear Community forum and intermittently (maybe 5%-10% of the time) it displays some Netgear forum Authentication error page and simply retrying then gets me in.
- amenicSep 17, 2020Apprentice
Yea when it's really bad the Chromebooks will fail the "internet" check (always DNS) which makes the system think the Internet is down when it's not.
I've also seen Windows fail this simlar check and think the NIC has no network connectivity BUT this doesn't stop it from working.
