amenic
Sep 17, 2020Apprentice
Intermittent DNS lookup failures on RBR850
Intermittent DNS lookup failures RBR850 I've been using the Orbi RBR850 for several months now and I'm constantly having issues with DNS that I've NEVER experienced with any other router I've ever u...
aparkins30
Sep 29, 2020Aspirant
I think I figured this out (at least for me)
I was having the same issues - Orbi defaults to setting itself up in router mode (versus access point). Since my modem is a modem/router, I disabled the wifi on my modem, set my modem up with an IP passthrough specific to the Mac ID of the Orbi router, then set the Orbi up as an access point. Fingers crossed but so far so good, haven't been seing the issue anymore.
Sep 29, 2020Guru - Experienced User
I would remove the RBR850 in AP mode from the IP passthru on the modem. THere would be no firewall or security in this configuration. SO you'd want to use the modems firewall for your security meaure while you have the RBR in AP Mode. FIrewall is disabled on the RBR when in AP mode.
- aparkins30Sep 29, 2020Aspirant
Didn't realize that, thanks for taking the time to reply. Just adjusted the settings.
- FURRYe38Sep 29, 2020Guru - Experienced User
AP mode on any wifi router or MESH router system, firewall is disabled.
And if you have a router upstream from the RBR while it's in router mode, this IS a double NAT configuration which can cause these problems. Just turning OFF the wifi doesn't resolve this.
