amenic
Sep 17, 2020Apprentice
Intermittent DNS lookup failures on RBR850
Intermittent DNS lookup failures RBR850 I've been using the Orbi RBR850 for several months now and I'm constantly having issues with DNS that I've NEVER experienced with any other router I've ever u...
Sep 29, 2020Guru - Experienced User
I would remove the RBR850 in AP mode from the IP passthru on the modem. THere would be no firewall or security in this configuration. SO you'd want to use the modems firewall for your security meaure while you have the RBR in AP Mode. FIrewall is disabled on the RBR when in AP mode.
aparkins30
Sep 29, 2020Aspirant
Didn't realize that, thanks for taking the time to reply. Just adjusted the settings.
- FURRYe38Sep 29, 2020Guru - Experienced User
AP mode on any wifi router or MESH router system, firewall is disabled.
And if you have a router upstream from the RBR while it's in router mode, this IS a double NAT configuration which can cause these problems. Just turning OFF the wifi doesn't resolve this.
