amenic
Sep 17, 2020Apprentice
Intermittent DNS lookup failures on RBR850
Intermittent DNS lookup failures RBR850 I've been using the Orbi RBR850 for several months now and I'm constantly having issues with DNS that I've NEVER experienced with any other router I've ever u...
musicbravo
Nov 18, 2020Guide
Seems like this is the same issue we discussed in a separate forum. I have started using rbr850 as a router again as I needed to block port 25 and my vm superhub3 did not afford me this option. Since doing this, the dns issues have returned. Think orbi will be back in ap mode soon and my ageing R7000 will get the outing as router again. I was working with the techs on this issue a while ago
Nov 18, 2020Guru - Experienced User
Are you using the DMZ or IP pass-thru on our Virgin Hub when you have the RBR in router mode? Or is the Virgin Hug bridged?
- musicbravoNov 18, 2020Guide
I have run the superhub in modem mode and in router mode with DMZ enabled. Net result is the same. I have jut flushed DNS on my laptop which, appears to be behaving for now. Sadly though my TIVO v6 boxes fall out with each other if connected to the ORBI, so have had to connect them back up to the Superhub, hence DMZ and router setup currently
- FURRYe38Nov 18, 2020Guru - Experienced User
Ok, thanks for confirming.
