amenic
Sep 17, 2020Apprentice
Intermittent DNS lookup failures on RBR850
Intermittent DNS lookup failures RBR850 I've been using the Orbi RBR850 for several months now and I'm constantly having issues with DNS that I've NEVER experienced with any other router I've ever u...
Nov 19, 2020Guru - Experienced User
Anyone here with a 7 series Orbi AX?
Try this:
- musicbravoNov 19, 2020Guide
Only thing I didnt try was the factory reset. Sadly I am now working from home again, so will not be playing with settings again until my connection is less critical. Cheers again FURRYe38 I will have another go at some point
- FURRYe38Nov 19, 2020Guru - Experienced User
Of course. I'm working from home too and have two VPNs running during the day for work so can't play around. :smileytongue:
- FURRYe38Nov 22, 2020Guru - Experienced User
For anyone in this thread, please disable any IPv6 Protocols ON the router. You might check your devices as awell and testi with IPv6 disable to see if this might help DNS problems. Let us know your findings.
